OBSPowerstroke
Mar 09, 2017Explorer
tnscoutr wrote:
I believe that I would just drill a hole and attach the strap with a bolt.
I want to avoid any drilling through the frame, if possible, especially at this location, since this one of the areas that was cracked and now is fish plated on both sides. Drilling would also be a pain since I would have to go through three layers of steel.
Frankly wrote:
If wires are broken it would show empty, if it is like most. Short to ground on the top sensor would make it show full.
Thanks for the troubleshooting info! The shop did have to work around the bundle of wires for the fresh water tank sensors, so hopefully the short to ground is in the exposed area above the axles and not covered up by the underbelly panel. If it's above the axles, it shouldn't be to difficult to track down and repair.
44,030 PostsLatest Activity: Jan 20, 2025
