goducks10
Mar 10, 2017Explorer
westend wrote:
If it was mine, it would get a self drilling screw into one or two of the holes in the hanger. I would have no worries about reducing the frame strength since the fastener fills the hole. The beam clamp that Todd suggests is also a good alternative.
Tank sensors are typically very fussy. You may wish to check your battery voltage to make sure you have 12V + in the battery.
One thing noted: Why is the drain plumbing against the spring shackle bracket? I see a piece of foam between them but that is a very poor setup for the pipe's longevity.
x2
44,030 PostsLatest Activity: Jan 20, 2025
