AirForceAngler
Apr 15, 2014Explorer
Can't help you with the tub, but there is a thread on here recently about modifying the plumbing to draw water from the drain location of the fresh water tank. This helps you to get almost all of the water out for use. Basically, you can thread a "t" into the drain, put a petcock on one end and connect the pump draw tube to the top side of the "t".
44,056 PostsLatest Activity: Jan 12, 2020
