Grit dog wrote:
BFL13 wrote:
Here is what I find confusing. It says leave your foot down and do not pump the brakes and the ABS will grab and release as required, but that is for coming to a stop. It does not seem to cover what happens on a long steep downhill run for keeping the brakes from overheating. Or does it?
https://www.icbc.com/partners/driver-training/Documents/ts274w.pdf
It's statements and questions like this that sometimes make me want to support those who just blatantly recommend more vehicle than needed for the job.
In other words, it's 2022 and if you don't even conceptually understand how ABS works and could somehow conceive that it will help a person who is riding their brakes down a hill, then you're grossly uninformed. Which is scary considering you drive a RV in the mountains!
Actually the whole 'more truck then what is needed' all depends on where one lives and travels. Lets face it, different parts of North America have different regulations.
While discussing and attempting to debunk the whole weight thing on another forum we got this information for BC:
"Here are two different documents that outline
GVWR maximums in BC, specifically.
Document #1Document #2"
The above comes with the mention of two popular tales:
The first being that they regularly have 'weight road blocks' and weigh everyone. While its rather unlikely to happen in most/all USA (they can't do roadblocks for drunks on NewYears Eve for example). No evidence of this actually happening.
The second is that at any accident it is standard practice to weigh all the vehicles involved and drop coverage on anyone that is over their GVWR. (no, I've not seen a actual insurance policy with this)
While I'm told that Alberta cares about the GAWR I have not seen a actual document to support that.
Where I live we have the following: https://www.oregon.gov/odot/MCT/Documents/weight_limits.pdf
I don't have any specifics on GM or Dodge but when it comes to Ford:
- F250/350SRW same axle (9700lbs) and breaks+pads
- F350DRW Dana80 (11K lbs), slightly larger master cylinder then above but the same rotors and breaks+pads as 250/350 SRW
- F450 Dana80 (11K lbs), IDK about master cylinder however larger rotor and pads (odd because BOTH DRW's 350/450 have same 14K GVWR).
While many of us only care what the actual hardware is capable of and will factor in (or not!) our own personal margin of 'safety' I recall a conversation I had with a commercial truck driving friend (+50yrs experience and runs his own trucking company and builds/plays with race cars as a hobby) that he and any of his drivers would/could refuse to haul a load that had <1000lbs margin of safety per tire. (he was rather shocked that I clocked +40K miles with just a few 100lbs margin!)
Lets face it, different people have different ideas/limits to what they consider 'safe'.
- Mark0
