DWeikert
Feb 25, 2018Explorer II
Mortimer Brewster wrote:
Stickdog, Dicor doesn’t give ANY directions on temperature application on the tube.
Just pulled out an older tube of Dicor I had here. The only thing this one says is-
Dicor Label wrote:
In cold weather, warm container at room temperature before use.
From that it would appear temperature doesn't matter, but I would still be concerned about surface condition. I would avoid conditions close to the dew point where there could be surface moisture you aren't aware of. Likewise below freezing for the same reason. But other than that it would seem long as the surface is clean and dry, go for it.
44,068 PostsLatest Activity: Jun 10, 2026
