hmknightnc
Jun 17, 2014Explorer
12volt DC lights should have exactly zero impact on AirCond operation if plugged into 110volt AC and your converter and battery are working properly and in good shape. With your description it is really hard to tell but I'm guessing your converter is not properly supplying 12volt so the battery is picking up the load in a depleted state causing your AirCond control voltage to get low enough to cause it to act funny. Your lights are 12volt DC Powered, obviously your AirCon is 110volt AC but it's control circuitry is 12volt DC.
- check your converter is putting out around 13.6 volts to the battery
- verify your battery is in good condition by having it load tested.
