Nvr2loud
Jun 10, 2014Explorer II
Lindsay Sorensen wrote:
We have checked all the fuses and they are all good. And have physically checked with a multi meter at the air conditioner unit and plugs and there is nothing.
Push the reset button on one of the plugs... likely the one inside the bathroom. That will most likely fix the outlet problem.
If the A/C still does not work, then you need to check the 12 volt fuses. I know you have already reset the 120 volt breaker and checked with a meter, but you need to check the 12 volt fuses. Pull them out and check with the ohm part of the meter.
44,056 PostsLatest Activity: May 04, 2014
