Nvr2loud
Jun 12, 2014Explorer II
Bob Landry wrote:Nvr2loud wrote:Lindsay Sorensen wrote:
We have checked all the fuses and they are all good. And have physically checked with a multi meter at the air conditioner unit and plugs and there is nothing.
Push the reset button on one of the plugs... likely the one inside the bathroom. That will most likely fix the outlet problem.
If the A/C still does not work, then you need to check the 12 volt fuses. I know you have already reset the 120 volt breaker and checked with a meter, but you need to check the 12 volt fuses. Pull them out and check with the ohm part of the meter.
The Op said in his last post, the one that you quoted, that he has checked all of the fuses. The button you are referring to wCI outlet and has nothing to do with the air conditioner. He needs to open the front of the converter and verify that the breaker is passing 120V(measured to neutral) and then go to the air conditioner and see if it's there. if it is not there, then there is an open or disconnected wire from the breaker to the AC. If both voltages are at the AC, then the circuit board on the AC is likely bad. Until these things happen, this thread is going to go in circles.
First Point: I did not suggest the GFIC had anything to do with the A/C problem. That is a second issue according to the OP
Second Point: I also stated that the OP had checked the fuses with a meter to ensure there was voltage. That test by itself does not indicate whether a fuse is good or not, especially when circuit boards are involved. I suggested pulling each fuse out and checking the ohm reading across the fuse. No ohm = open fuse = faulty.
After VERIFYING that all fuses are good then you can certainly proceed to other tests. I would have started with checking voltage at the places you described. I just wanted the OP to be sure that she had good fuses.
44,056 PostsLatest Activity: May 04, 2014
