srgallan's avatar
srgallan
AC leaking when running combined with heavy rain
Hi folks,
Question I wanted to post to the group here as I try to find more information sources. Picked up used 2019 TT August last year and noticed this year that if the AC is running and we have a lot of rain we see water dripping inside. If not running during the rain there is no water.
I already had mobile service from the dealer come here and say they could not find anything and drain was not clogged and last time they ran into this a new AC was installed to fix it. He did clean the drain a bit.
My thought if it was to happen again to have a new gasket installed if possible but have no ideas. Any suggestions?
  • TXiceman is correct to a point. Coleman units have four bolts. They have a spring around the bolts to keep unit tight as the gasket compresses. You have to urn bolts like 4-? turns so snug it up.
    Bolts are accessed from the interior of the rig by removing ceiling unit.
  • Thanks all, appreciate the input. I have never removed the AC unit so will spend some time googling that and give it a go with a friend to see if that fixes it.
    @enblethen - it's a Coleman Mach 1
  • First, is water leaking in, or is it condensing inside the unit and dripping? When mine starts that I open a high window, and rig a fan to blow out. Normally stops fairly soon.
  • Don't over tighten the 4 bolts as this will crush the gasket. Tighten no moe than one fill turn on each.
    If this does not stop the leaking, you will need to remove the a/C unit and replace the gasket. DO NOT caulk the gasket. The gasket should not be tighten more than what it takes to compress the gasket by 1/2. Tighten all 4 bolts equally.
    Ken
  • You could tighten the AC unit mounting bolts as the gasket may have settled.
    Make of AC unit?
