Takamine's avatar
Takamine
A/C on 20 amp
When I'm at home, I use an adapter and plug my TT into a 20 amp outlet. I've heard that you shouldn't run your A/C when only plugged into 20 amps, but the breaker for the A/C in the TT is only a 20 amp circuit. Should there be any issue running the A/C with only 20 amps, if nothing else is running? Thoughts?
Thanks
