maxwell11 wrote:
my 2005 Dodge diesel 2500 truck is not cooling properly.
I used my laser red dot temp gauge to check the temp of the air coming out of the vents.
temp was about 46-52 degrees max
should the air coming out of the dash vents be colder than that?
will take it by the dealership and hopefully they can add some gas to the system.
again, I say hopefully that is all it needs.
Is the truck sitting still when checking the temp?
Do you have it on recirculate?
Where do you have the fan speed set?
They will not cool to their max until you are running down the road.
