SidecarFlip wrote:
On the not so Fantastic Fan, If you are going to put one in, I'd suggest looking at alternative models. Reason I say that is the one I have failed 3 times before I got a good one. That is three motor / fan assemblies before I got a good one and even though they warranted each one, the motors cannot be disassembled to attempt a fix, the cases are welded together.
Of course the motor / fan assembly was made off shore.
Very sad how they've gone down hill after the buy-out.
When you get one that works, the new motors are noisier too.
I would definitely compare other brands.
