sign_man
Nov 07, 2013Explorer
ac unit
1)i am looking to purchase an ac unit for my 815 tc. i want to be able to run it with a honda 2000 gen. i frequent temps in the 95+ range. anyone have this setup, and is it sufficient enough? 2)als...
Exlporer wrote:
Having just purchased a camper and A/C I learned that the Polar Cub is no longer manufactured! Current production is the MACH 8 CUB 9200 BTU it is part of the new Mach 8 family but be careful with the name mach 8 as most of those units are the larger 13.5 BTU.
Here is the model number for the 9200 BTU MACH 8 CUB 47201A876
They still show alot of the Polar cub info in the technical section of www.rvcomfort.com and if you compare the old polar cub specs (49000 series) you will see that the Mach 8 cub is very similar.
Several e-mails with customer service at www.rvcomfort.com over a period of days finally got me straightened out....I was about to make my dealer change out my A/C unit until I learned they had installed the current production "CUB"! I'm going to be testing mine with a Honda 2000 soon.
