1)i am looking to purchase an ac unit for my 815 tc. i want to be able to run it with a honda 2000 gen. i frequent temps in the 95+ range. anyone have this setup, and is it sufficient enough? 2)als...
The lower the btu rating the more readily a Honda 2000 will be able to start it up and keep it going. A lower btu rated AC will also be more efficient and more effective in removing moisture from the air. A higher rated AC will run for a shorter period of time and get the temp down but not remove nearly as much moisture from the air inside.
