1)i am looking to purchase an ac unit for my 815 tc. i want to be able to run it with a honda 2000 gen. i frequent temps in the 95+ range. anyone have this setup, and is it sufficient enough? 2)als...
The id motor is the fan motor that circulates the air inside the camper , it has low .7 amp and high .1.2 amp speeds .The od motor is only one speed all the time 1.6 amp , it blows on the compressor cooling fins Added together on low- comp 8.9 , id.7 , od. 1.6 = 11.2 amps on high -comp 8.9 , id 1.2, od 1.6 = 11.7 amps
