Gsragtop's avatar
Gsragtop
AC upgrade, questions and issues.
So as some will remember I'm the guy who purchased a brand new 2015 TT, and was sorely disappointed with the performance of the factory 8,000 btu wall unit..
After going back and forth with the dealer/manufacturer it because obvious this was a me issue and not a they issue. So I found a 12,000 btu unit that was similar in hight, and width, but 6 inches longer in depth.. I spent all day rengnering the box that holds the ac and did get it monted., Great news is when I'm done it should look close to factory.,
So my questions/issues.
1) about two weeks ago another member posted a question about the black vent on the roof of his unit above the ac.. The general consensus was that it was a vent for the AC so it could breath.. When I removed my unit from the hole, I was surprised to see a solid roof above it.. No vent at all??? Is this an oversite or is this correct ?? I also have the vent on mine.
2) after getting the unit up and secure the first thing I did was plug it in to see if it worked.. It would run for about a min and then click the compressor off, and then start the compressor again about 3-4 min later for another min. At first I'm thinking FUDGE bad unit.. However after thinking about it some more, I was running the unit on a very long extension cord then thrugh a 15 amp-30amp adaptor. Could my issues be due to a power issue?? I tried another extension cord which I think is a higher gauge with a built in curcut beaker and it tripped after about 3 min., if that helps
Thanks again in advance. I have a few other questions I'm trying to figure out. Will post later.
