SoundGuy
Dec 15, 2017Explorer
Lynnmor wrote:
To reduce the humidity inside the trailer, water needs to be removed and taken outside. Explain how Damp-Rid takes those many gallons of water out of the trailer.
Any desiccant absorbs moisture from the air ... I use Dri-Z-Air myself and find it does help control humidity levels inside the camper during winter storage. I place the container in a pan so if should overflow it will do so into the pan rather than on to the trailer floor. I try to replace the desiccant material periodically so overflow doesn't usually happen. Works for me. :B
