Phanes's avatar
Phanes
Acessories for a TT
So it was suggested I start a new thread on this.
I am going to buy
1. A surge protector for the RV any suggestions on what I should buy?
2. A cover to protect it while it is in storage for the winter any suggestions?
Do you guys have any suggestions on any must have accessories?
Thanks
  • The stick on tap lights are great for having useable light in the camper without using your batteries.
  • The reason it will not let power thru is it is seeing no ground and that is a nice feature when plugged into the pedestal because you want to know if there is a open ground. All ginnys usually do not have a ground. Simple flip the little switch to bypass the management & let power thru when using a ginny.
    trail-explorer wrote:
    If I do a Progressive EMS system again, I will go portable.
    The thing I don't like about the hard wired version is it won't allow power in from my Honda EU2000i until I flip a little switch on the remote of the EMS.
    Ditto on the power drill. There's a huge thread on that right now.
    Water pressure regulator for when you use city water inlet at a campground.
  • Rhino sewer hose.
    A mat of some type to go at the bottom of the steps, and a rug for just inside the door.
  • Progressive Industries makes the absolute best EMS and they even come with a life time warranty.
  • If I do a Progressive EMS system again, I will go portable.
    You don't want just a surge protector but an EMS (Electrical Management System) that includes surge protection. You can't go wrong with a Progressive Industries EMS such as a portable EMS-PT30C or hard wire EMS-HW30C. Progressive has announced improved versions to be released in Jan so you might want to wait a bit before making your purchase.
  • HERE The best investment to keep your fridge tempts low in the extreme heat. It is what I have.
  • A battery operated drill for the corner jacks and an electric tongue jack if using a WD hitch.
    If you'll be in an area like the south west, get a three filter set-up for your water.
    Bill
  • For either one search this Forum for `surge protector' or `cover'. Lots of previous discussion. We have both.
