jlatenightExplorerJun 14, 2022add an outlet to the outside kitchenI'd like to add an outlet to the main area of the outside kitchen. I plan to tap off of the mini fridge outlet. That outlet has two separate romex cables going into it and it only has one outlet for...Show More
CA_TravelerExplorer IIIJun 14, 2022You could have a GFCI and/or a inverter outlet. You could use either one but the new outlet should be a GFCI.
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringOutside kitchen?Outside kitchen.Electrical outlet issues
