fdwrench's avatar
fdwrench
Adding a 12 volt power point
Hello,
I am working on my Outdoors TT. I would like to add a 12 volt power point. I can get 12 volts at the battery switch easy but am having a hard time finding a decent ground without making holes in the floor. There is a 120 outlet very close.
Is there any reason I could not tie into the ground at the outlet? I believe that it goes straight to the frame.
Thank you
Ed
  • I put a 12V socket just under the edge of the kitchen counter. Tied into the LP/CO detector wiring just below near the floor. Possibly just need to pull a drawer out and find the wires going to the detector. Should be at least 16ga wire there, possibly larger.
  • RoyB's avatar
    RoyB
    Explorer II
    All of my 12VDC items that is controlled by the 12VDC Power Distribution Panel has two wires running to it usually from a 2-conductor marine grade cable. The Black wire is positive +12VDC and the White wire is negative -12VDC. Nothing that these DC cables control need to go to the actual trailer frame ground. Both the positive 12VDC and the negative 12VDC leads are terminated at the 12VDC Power Distribution panel where the fuses are located.
    Mine looks like this
    This is another pictorial on using my ON-BOARD Power Distribution Panel for wiring
    When I am working with the batteries and battery switches etc then I do run some frame ground DC wiring, This is usually under the trailer or outside on the tongue area or maybe on the basement wall next to the front of the trailer.
    My on-board Converter/charger and power distribution panel do have a frame ground cable installed. If I have an optional INVERTER installed inside the trailer than I will run a frame ground cable to it as well.
    The point I am bringing here is all of the inside DC appliances and the lights etc all have a 2-conductor cable feeding them that is carrying both + and - 12VDC wires.
    Just the high current paths around the battery banks may use the frame ground as an conductor...
    This is the way my OFF-ROAD POPUP camper is wired at any rate...
    Roy Ken
  • donn0128 wrote:
    You cannot mix voltages. Do not do it!!!!!!
    Your far better off drilling holes to run dedicated 12VDC.
    Remember, you need to complete the 12VDV circuit to have it work.
    X2 !!!!
  • Interesting, I haven't closely at the AC versus DC wiring on trailers... but I am not sure why a ground isn't a ground for either systems. I think you just have to make sure that the ground is indeed a ground and NOT the neutral.
  • You cannot mix voltages. Do not do it!!!!!!
