tshirtman's avatar
tshirtman
Adding a Skylight?
Thinking about adding a skylight in the living area. Any thing wrong with that and is it a major project.
Thanks to all:)
  • Fantastic Vent has a clear/smoked plastic cover on their fands and vents, that gives a nice view of the stars and weather. Fits a 14 inch hole you might already have. I have both the fan, and the plain vent in my 1969 Terry, and love the view at night of the stars.
  • From about year 3 of my new 5er, the skylight was a constant source of leaking. The ceiling fan hole and the shower skylight never leaked, but the big living room one did. I tried Eternabond and Dicor, neither of which stopped it.
    I finally found Heng's Rubber roof coating, which goes on like paint and gets in every possible hole. I finally got it stopped. I redo it every year.
    Good luck with your skylight project!! ;)
  • Can be done, but like mentioned above, extra framing will need to be added - framing that surrounds the opening of the skylight so you have something other than roof plywood to screw the skylight's mounting flange to.
    Me: I am not a fan of the skylight in my truck camper because it's a source of heat loss in the winter, and incoming heat in the summer.
  • "Major Project"???
    I guess it depends on how handy you are.
    You will have to add extra framing and of course you will have to cut a major hole in the roof (and that's the part that scares me).
    Of course you are aware that leaks are the real, "major project," when it comes to RV's.
