Passme
May 01, 2017Explorer
Adding batteries
Well my WF-9855 converter is behaving just like everyone says, no bulk charge available regardless of SOC. And as usual it's gotta be the garbage factory wiring, it's 20+ ft. to tongue mounted Interst...
westend wrote:
Anyway you slice it, the WFCO converter will not produce 14.8V (Trojan's charging specification). It's doubtful that a relocation of batteries and a larger cable will get the WFCO to produce a true bulk charge cycle. I don't own one but am referring to the posts on this Forum and others, about the charging aspects of the WFCO converters.
An easier solution may be to replace the converter with one that does a true bulk cycle at 14.8V. Progressive Dynamics makes one, as does Iota.
