bondebond
Jul 06, 2015Explorer
Adding that much weight isn't adding THAT much weight as not even 100% of what you add will be distributed to the tongue. I have found that my PUP rides much better if I get more towards 15% tongue weight than anything less. I have weighed my tongue and it is ~420 pounds, which is about 14% of GVWR. The actual percentage is technically higher because I don't load quite up to the GVWR of the PUP (3,200 pounds).
Other than not making the bracket taller than the top of the wall of the PUP so your bed can slide forward, I don't see any problems. You would want to ensure an adequate bracing design to account for sudden changes in velocity and and direction. You wouldn't want an emergency action to cause it to break loose and go flying across the highway.
