colliehauler
Apr 20, 2015Explorer III
carringb wrote:Sorry my mistake.colliehauler wrote:ROBERTSUNRUS wrote:You are living in the past, see my post.vacuumbed wrote:
Good info.
I have a 2003 E450 with the V10 that doesn't have factory cruise. I'd like to add it as well. I assumed there is more parts to it than just the switches on the steering wheel.
:) Hi, when I worked on them, (decades ago) they had their own speed sensors, a servo/actuator, secondary stoplight switch/dump valve, and control module. I would not trust an aftermarket system.
A 2003 V10 will need the vacuum/cable bits and pieces installed as well. I think valve is controlled by the PCM however. Drive-by-wire came out in the 2005 V10's.
44,067 PostsLatest Activity: Jun 05, 2026
