Huntindog
Jan 02, 2018Explorer
SoundGuy wrote:Do you EVER agree with anyone?Huntindog wrote:
There are advantages to both approaches. BUt overall, long term the heat in the TT will be the same.
Incorrect. Warm air rises - a heater situated on the floor is generating heat where it's needed, warming the interior of the camper and occupants as it rises and is distributed about the camper. :B An A/C mounted heater is generating heat where it's not needed, at the ceiling, where it's trapped and there is no one to benefit from that warm air. :( The only rationale I see for an A/C mounted heat strip is for blowing warmed air into the bed ends of a hybrid trailer, otherwise it's a useless exercise in futility when a $20 floor situated electric heater will prove far more effective at distributing warmed air where it's needed.
Back to what I said, I will now explain in greater detail.
5K btu is 5K btu. This is a fact.
If you run a portable 5K heater in a TT for 24 hours straight and a 5K heat strip in a TT for the same amount of time... They will BOTH stabilize at the same temps. (identical TTs and conditions)
But most everyone won't run a portable unit 24 hours straight due to safety concerns. But a permanent install of heat strips is perfectly safe to leave running night and day, when you are sleeping or away. So if you are in a campground where the elec. is "free".. Then this is an advantage.
Don't obsess over the heat rising thing (I know it's hard but try) as that is what the fan is for. Blowing the warm air into the TT and mixing it with the cold air.
44,071 PostsLatest Activity: Aug 23, 2026
