gmw_photos
Jan 02, 2018Explorer
pianotuna wrote:
....snip....
Oil filled heaters do not share that risk.....snip
.... At least one of our long term members "cheats" and puts a small fan on to blow on the oil filled units.....snip
When I am at home n the S&B in the winter, I use one of the oil filled rads in my kitchen, which is where I spend most of my time. I too cheat with a little fan. I found a small "personal fan" like you might use on your desk at work. About two and a half inches diameter. I set it on the floor aimed at the base of the oil filled rad, and some measuring with the non contact IR thermometer showed I was able to pretty much even out the heat of the radiator top to bottom, plus move a little bit of air.
44,071 PostsLatest Activity: Aug 23, 2026
