pianotuna
Jan 07, 2018Nomad III
Hi myredracer,
I have pillows in the vents and skylights. I have the windows in the rear bedroom covered with Insulbright. But I'm not using most of the other cold weather modifications. The heat strip was cycling while maintaining 72 f.
It is a Canadian made unit, but pretty similar to other class c's which have dual pane windows.
myredracer wrote:
If you can maintain that sort of temp. at freezing temp. on only 1700 watts, that has to be a very well insulated RV! Are Class Cs that much better insulated than TTs?
