JBarca
Oct 15, 2022Nomad II
Baja Man wrote:
I found the wiring diagram.
Can someone explain the small box to the left side of diagram?
The fan (part V) is show wired differently in both diagrams. One shows that one wire (negative) from goes straight to ground and in the other diagram it shows one wire (negative) goes to (R, K, J2, G, J10, Ground) switch, heating cable, lamp, J2, J10, and ground.
Thanks
Your diagram is fuzzy and hard to read. But the fan appears to be wired the same in both diagrams. What looks different is the boxed area on the lower left shows other ground connections that can maybe be confusing.
If the fuzzy words on the top right of the boxed area says, GROUND, then both diagrams show the same thing. A +12 VDC hot wire feeds what looks like a fuse. Then the fuse feeds a thermal disk switch which then feeds the fan. The other wire on the fan goes to ground. Both drawings show that, it just looks different as the boxed area has other grounds connected to the same ground coming off the fan motor.
Hope this helps. If what I said above it not clear, please create a pic zoomed in we can see all the words etc.
John
