Jay_PatExplorerMay 23, 2017Adding higher, stop and turn signals on tt.I ordered some LED stop and turn signal lights to mount up high on the rear of the travel trailer. Original plan was to run the wires along the outside surface of the travel trailer. I had planned to ...Show More
CA_TravelerExplorer IIIMay 23, 2017Also consider the window for access. You might for example be able to remove just the inside trim to get good access.
Related ContentAdding power outlets in slide with no wiringHigher end brands?Trailer Wiring - Added Side Turn SignalsPSI when using higher load range tires.weak Cell Signal
