Jay_PatExplorerMay 23, 2017Adding higher, stop and turn signals on tt.I ordered some LED stop and turn signal lights to mount up high on the rear of the travel trailer. Original plan was to run the wires along the outside surface of the travel trailer. I had planned to ...Show More
BmachExplorer IIJul 03, 2017I saw a utility trailer that had three factory installed brake lights going up each side. You could not miss it.
Related ContentAdding power outlets in slide with no wiringHigher end brands?Trailer Wiring - Added Side Turn SignalsPSI when using higher load range tires.weak Cell Signal
