pianotuna
Dec 06, 2015Nomad III
Hi,
For 6 years I charged 875 amp-hours of lead acid batteries from the OEM 140 amp alternator.
Use a Kill-a-Watt meter to check the maximum draw of the laptops. Do this by running one down until it goes into suspend mode, then plug it into the kill-a-watt and start a disk defrag or other program that will cause the drive to spin. Make sure the screen is on the brightest possible setting.
Once you have that number, double it and multiply by the number of hours you wish to have power, then divide that by 0.75 to find the LI battery bank size in watt-hours.
To add solar take the total number of watt-hours and divide by 5. That ought to give you the panel wattage.
Do not forget the power needed for any internet connection in the calculation. It is small but in fringe areas a booster may be needed too.
44,071 PostsLatest Activity: Aug 30, 2026
