Huntindog
Aug 28, 2021Explorer
valhalla360 wrote:It certainly is what cambering is. Do some googling as I did. There is more than one way to do it. But I found articles of some really big semi type stuff being cambered by welding. In addition at one time, Northwoods RV had a picture of welds on one of their frames stating it was cambering for more strength. I also toured the Palomino Sabre factory back in 2010 when I bought my Sabre. I took a lot of pics. One of them shows the cambering welds. I have that pic, but I haven't posted a pic in so long, I forgot how to do itHuntindog wrote:
There is more to this than what meets the eye.
Most trailer frames are "cambered".
This is running weld beads at specific locations and patterns on the frame rails. This process slightly bends the frame, and more importantly strengthens it while adding a springyness to it. This allows for a lighter frame to be used, as the cambering puts the strong points just where it is needed. The locations/type of cambering are determined by the engineers,based on the expected loads for each trailers design. I became somewhat educated on this when having a sidebar dialog with Jbarca on a frame repair project he was undertaking. Curious about what I was reading, I grabbed some 10' metal stock from my pile and sparked up the welder. It was very enlightening. Each weld bead I ran caused measurable movements in the straightness of the stock compared to an identical unwelded control piece. More importantly the feel of the cambered stock changed dramactically. It felt more alive, with a definant springness that made it want to bounce back to its unloaded state as load was applied to it. The control piece felt dead and weak in comparisson. with out the "bounce back property of the cambered piece. IOW, applying enough force to permanently bend it was much easier.
As to what this means to what you plan on doing: I would only apply such force at a location that it was designed to take it. A jack as close as possible to the wheels should be pretty safe. Other than that, is a roll of the dice. You could end up applying force in a direction where the cambering is in the wrong direction to the force you are applying. Nothing good could come of that.
Your frames cambering can be in different locations and directions, and can be impossible to see once the trailer is built.
That is not what cambering is.
Cambering is building an unloaded beam with a curve such that when it is loaded, the load bends it back to straight.
I've never seen a travel trailer frame with cambering...certainly no geometric weld patterns and it doesn't add springiness.
That said, I do agree that if you are going to lift the trailer, doing it at the intended support points is the best idea.
And welding certainly does change the way a length of steel feels.
I tried it and felt it it myself. If you still don't believe me.... Break out a welder and see for yourself.
