2oldnslow
Dec 18, 2016Explorer
I did that with Anderson connectors. The camper-side connector is screwed to the camper wall right above the access door so I can plug the cable from the battery in with one hand - easier than 2 loose leads.
The problem I see with the single-pole connectors is that it is possible to connect them backwards with catastrophic results. The Anderson (and the OP's connector) can't be connected wrong once they are wired correctly. Very important.
