bb_94401
Dec 18, 2016Explorer
mcc272 wrote:
.... It might make sense to put some form of disconnect in the positive side to allow a no load connection.
One thing that was not clear (but I may have missed it) is the question of polarity. It seems to indicate, but not clearly, that the plugs have polarity which would be nice so that they only go together one way, pos to pos and neg to neg. Avoiding sparks and explosions is always good when working with electricity. ....
I have a Blue Sea Systems P/N 6006 single circuit ON / OFF switch wired to the positive terminal of the PowerMod HP bulkhead connector, just inside the TC.
I also used pressure sensitive tape to attach a Mega Fuse to the battery. Blue Sea Systems also has a MRBF Terminal Fuse Block that attaches to the battery. Their fuses themselves are a little rarer than MEGA or ANL fuses.
The polarity of the PowerMod HP connector is maintained by the triangular piece in the center of both parts of the connector. In the correct orientation they slide by each other and allow the contacts to mate. In the wrong orientation the ends interfere with the connection.
44,070 PostsLatest Activity: Aug 06, 2026
