JoshuaH
Nov 06, 2020Explorer
Adding tank heaters for winter use.
My wife is an ER nurse, obviously not the safest profession right now. She has been using our camper (Wolf Pup 16HS) for isolation when needed, however now we are heading into winter.
My question is, if I add tank heaters, would this camper be safe to use in below freezing weather if needed? How cold can you still go safely? I realize wind would be a big factor as well.
Is it better to use a heated fresh water hose or to just fill the fresh water tank and put a heater on it as well?
Will I also need to somehow heat the drain valve and pipe or will the heat from the water in the tank transfer to the water in the drain pipe and keep it from freezing as well?
Any and all advice for setting up this camper for below freezing temps is very much appreciated. I want to have it ready to go so if she gets exposed or worse gets Covid the camper is ready to go for her on short notice.
Thanks!
Thanks!
