Huntindog wrote:
GordonThree wrote:
afidel wrote:
The Wynn's really like their dometic 120/12/24v freezer and they're on a boat in the tropics so anything short of the desert is going to be easier by comparison.
My level of funding is not quite up to what that young couple enjoys. I'm sticking with a ~$150 unit from home depot or walmart...
I carry a cheap 5.0 cubic foot freezer on my rear rack. I installed a toggle switch to bypass the T-stat. So when I am boondocking, I can make sure that the freezer never shutsoff when on generator power. It will pull down to 40 below. Then it can last a loooong time before needing to cool down again.
I did have to make a custom cover so the rain would not freeze the lid shut.
I used coroplast and eternabond. It fits like a glove.
I like that idea for the cover... does it fit like a cap? covering the lid and down the sides just a bit? that's how I picture it at least.
I was thinking of bypassing the t-stat as well, put in my own cut out t-stat set to a higher temp, so I could have the freezer work like a fridge instead, depending on needs.
