Sorry, I just looked at the specs, and you are even more OVERLOADED than I first suspected.
The Torque T32 has a DRY weight of 9500 pounds. Actual empty weight is probably at least 1,000 pounds more than that. And 1200 pounds is the DRY tongue weight. Actual empty tongue weight is probably at least 1,400 pounds.
Finally, GVWR of the trailer is 14,000 pounds. This is skirting 1-ton territory.
Sorry the dealer misled you into thinking you can safely tow that trailer. You can't You are overloaded by every metric.
