sonuvabug
Sep 23, 2016Explorer
Much has been covered already. What about the weight of fuel (8.5 lbs. per imp. gallon for diesel, 7.3 lbs. per imp. gallon for gasoline)? Didn't see a separate line entry for fuel unless you already factored it in somewhere else.
If you haven't already installed them, look at Sumo Springs as an alternative to the Timbrens. I did a ton of research when looking to address my "rear end" issues and I went with Sumo's.
Also, your resale on a regular cab will likely be less than with a SuperCab.
44,071 PostsLatest Activity: Aug 16, 2026
