manualman
Sep 21, 2016Explorer II
I'm not so sure that a "one piece roof" is automatically a good thing. The Colemans in particular had a lot of problems with their solid ABS plastic sagging and cracking.
The old school aluminum roofs are more fragile and are totally dependent on good caulk maintenance, but if you DO that good maintenance they are the better choice. With the one piece roofs, you are a helpless bystander. There is nothing you can do to improve your odds of success. Either it holds up or it cracks. Aluminum is better for the diligent owner. One piece is better for the sort of guy who needs a mechanic to change the air filter on his car....
Decide for yourself which sort you are.
44,068 PostsLatest Activity: Jun 01, 2026
