Bedlam
Oct 06, 2016Moderator
Redneck bling wrote:
So, I see the hellwig anti sway is about 247...
The firestone air bags can be had for 335...
hellwig helper springs are 331 for 3500 lbs and 300 for 2500 lbs.
I have had firestone bags before. Are they performing the same duty as the helper springs? And which spring stack....the 2500 or the 3500? Seems the 3500 would elliminate the need for the air bags?
SDTruckSprings.com has the leaf packs you want. You shouldn't need bags if you get the right spring combination and preload set.
44,056 PostsLatest Activity: May 04, 2014
