Golden_HVAC wrote:
The dually 3500 should have a great cargo rating, especially if less than 3 years old. However some of the 2000 and earlier Dually GM's and Dodges only had a 10,000 GVWR, about what is found on a 2005 and later F-250 pickup with single rear wheels. The current F-350 dually has a 14,000 GVWR, and cargo rating above 5,500 pounds.
So what cargo rating do you have? Or what model year and GVWR do you have? The diesel has a 600 pound heavier curb weight than a gas engine pickup, thus can normally carry more with the gas engine.
Good luck on your search!
Have you checked RvSearch.com They are set up by the same company that hosts Rv.Net. . .
Fred.
Fred,
Thanks for that info. It's a 2010 Dodge Ram. It's a diesel. I'm not sure what the GVWR is. Hmmm...
Susan
