Grit_dog
Feb 09, 2021Trailblazer
Geo*Boy wrote:
I don’t believe a heavier swaybar is going to make a big difference. The Timbrens will move the suspension point of contact farther outboard making the load much more stable. They are easy to install and much less expensive than the larger swaybar
Sway bar will absolutely make a noticeable difference. Without it, all the suspension upgrades are making it more of a bouncy house with nothing to control them.
Although based on Jaycocreeks weight statement, if the OP has the same camper, idk how they are even hauling it without extra spring capacity currently. Even at say 3500lbs, it must be sacking out the springs real bad.
44,071 PostsLatest Activity: Aug 16, 2026
