Terryallan
Sep 14, 2014Explorer II
fatheraccountant wrote:
It was suggested that I start a new thread regarding the following question:
We are relatively new to RVing. We have a 30' Sunset Trails ultra-light (6,400#) empty. We've been using our son-in-law's Tundra but we're seriously considering a F-150 3.5L with Ecoboost. The ones we're looking at have a 3:43 rear end. It sounds like this truck should handle our trailer. We're kind of resigned to getting lousy mileage when towing but would like to get the best we can the other 95% of the time. Any thoughts?
To clarify, the 6,400# is dry weight, not scale weight under tow. Therefore, the total weight of the trailer under tow is probably in the 8K range.
Still: same question, second verse - how do you think a F-150 3.5L with EcoBoost will do?
You may want to look again at the truck. Ford does NOT offer a 3.42 rear gear in their trucks. they offer 3.15, 3.31, 3.55, 4.10, and 3.73.
Tow capacity for F150 Ecoboosts range from 7300lbs to 11,300lbs, depending on the rear gear, AND the GVWR of the truck. You will need a pretty high GVWR to get over 8000lb tow capacity. you will need at least a 14000LB GCVWR to get over 8000lb tow cap. And that will only get you 400 to 800 over depending on the truck
44,066 PostsLatest Activity: Apr 10, 2026
