APT
Sep 15, 2014Explorer
The 3.5L Ecoboost will tow similarly to the Tundra. Maybe a little lower engine speed, fewer downshifts. 7500-8k loaded means 1000 pounds of TW. Make sure any vehicle you find has the payload to handle whomever will be riding in the truck when towing, some gear in the bed, and the 1000 pound TW. Half ton payloads range from under 800 pounds to over 3000 pounds. Most crew cab half tons are in the 1300-1500 pound range. Take a look at this sticker on each truck's driver's door or door jam for as equipped payload as you shop. Make sure the number where mine says 2051 is enough for your needs.
44,066 PostsLatest Activity: Apr 10, 2026
