Ron-C's avatar
Ron-C
Aerodynamics Matter !!
Hello All. First post here... wanted to share some data on aerodynamics.
I am designing an ultralight (under 100 lbs/ft) small travel trailer and wanted to find out the effect of shape on aerodynamic drag. I modeled up 2 trailer designs using SolidWorks CAD software then applied CFD (Computational Fluid Dynamics - a virtual wind tunnel) to test them.
The baseline trailer was a box shaped design with slightly rounded corners - essentially flat nosed cargo trailer. Then I created 4 versions of a swept profile trailer steeper at the front and with a longer sweeping tail in different widths.
Results showed that a swept profile trailer 7" wider than the baseline box trailer at the same height would have 45% less drag force. Looking at it the other way around, it would take almost twice as much force to pull the box trailer!
My conclusion, the shape of the trailer is way more important than the size of it. This means that a larger trailer would require less fuel to pull if it is the right shape.
There are lots of other factors including the shape of the tow vehicle, speed, temperature, etc. but this is at least some food for thought.
Now I am working on a developing an aerodynamic shape that is functional :)
Ron
  • regarding real world aero effects on fuel mileage. I tow this box shaped camper I am in right now ( funfinder 189 FDS ) ....7 feet wide, 10 feet tall, 19 feet long including tongue. Sloped back front, the rest of it sq edges, with my Nissan Frontier. Overall fuel average over approx 25K miles has been right at 11.4 mpg.
    I also tow a two horse trailer with this truck. Lower roof height ( whole trailer is lower to the ground due to torsion axles, and wheels being set outside the box. Rounded front end, rounded corners similar to an Airstream design ( except the back, which is square ). Approx same weight as the camper. I get approx 1.5 mpg more pulling the horse trailer with same truck, same speeds.
  • gmw photos wrote:
    downtheroad wrote:
    ....snip.....
    Compromise. No one wants a trailer that gets marginally better fuel mileage and then gives up livability, cabinet and storage space, head room, etc...
    Well, some do ! Those who buy an Airstream, or some of the smaller fiberglass egg campers for example.
    Everyone has their own reasons for purchasing the RV they finally get, but I've not encountered too many (if any), that purchases an egg style or an Airstream because of the airodynamics. Everyone I've run into has them because, Airstream is a better built trailer than the average, and Egg shaped trailers are just smaller and can be towed with a smaller vehicle, quite possible to get one in a tall garage or easily behind the house so the HOA snoop won't see it!
  • downtheroad wrote:
    ....snip.....
  • But! You are leaving off the airodynamics of the tow vehicle and how the wind rushing off the tow vehicle impacts the front sail of the tow vehicle.
    Depending on the tow vehicle and how the wind deflects around it, the same trailer can give considerable resistance with one tow vehicle, and simply sweet with another.
    You have to take into account the tow vehicle. Trailers don't tow themselves.
    Welcome to the forums!
    Independent engineering is what makes this country great! Keep working on it!
    Edit: An open bed pick-up truck will cause a vastly different airodyanamic flow than one covered with a full shell. A van will have a different airodynamic drag too. Wide duly have a different dynamic than single rear wheel trucks, and the height of the truck makes a difference too.
    Lots to think about.
  • that sounds like a fun and interesting project. Can you run the software computing drag with a tow vehicle in place as it would be in the real world ?
  • No doubt, the "sail affect" is a factor.
    But, while you are designing the outside shape of your trailer, keep in mind that the outside shape will also determine to some extent the inside shape..ie, the usable room and configuration inside.
