Buzzcut1
Mar 21, 2015Nomad II
Ok right up my alley. The truck that is. I don't care which brand of SRW you choose You will need to upgrade to 19.5 wheels and tires. My non slide Lance 1055 which is close to the same size tc as the 1050s with minimal gear pushes 7500 pounds on the rear axle. That is a no margin for error load on 99% of the LT tires out there. With 19.5s and Vision wheels and 245/70R19.5s you are at 9000 load capacity, and up to 9600 with Rickson wheels. Lots of sway and blow out risk with LTs not much with 19.5s. Go Dually if you can or go SRW with 19.5 as a second choice.
none of those 3 TC's in your list is a lightweight
