brholt
Mar 21, 2015Explorer II
Truck camper magazine estimates the wet weights of these three campers as:
AF992: 4,948
EC995: 4,533
Lance 1050S: 4048
Maybe with a gas engine in a low trim regular cab you could carry the Lance and not exceed your GVWR. Probably not the EC and certainly not the AF.
A dually can do any of these safely. As pointed out if you want to push the GVWR in a SWR the 19.5 rims and tires are the best bet. Some just replace the tires with higher rated E load tires but at least be sure your rims are up for it.
As also noted the AF1140 (5,286 lbs) and AF1150 (5,179) dry baths do not weigh much more and since you are in dually territory you might want to consider them.
AF992: 4,948
EC995: 4,533
Lance 1050S: 4048
