ktmrfs
May 16, 2019Explorer III
good WD hitch, dual cam, equalizer, etc. and he should be good to go.
If he is going to travel a LOT and be on roads with frost heaves, concrete joints etc. A AirSafe air hitch will make the ride much better on roads like that. We have one, and well worth it for the amount of travel and the roads we travel on. However, it's not for everyone. First it is heavy, near 100lbs, and it is NOT inexpensive, $700-1000 depending on which one you get.
It does however work with a WD hitch no problem.
Our trailer is about 32', actual tongue weight fully loaded 1450lbs, and even when the truck is loaded to max GVWR (10K) with WD set up, towing is NOT an issue, nor is control.
44,065 PostsLatest Activity: Apr 14, 2026
