- LarryJMExplorer II
ScottG wrote:
Bols2DawaLL wrote:
Ummm . if you don't have a factory tow package and you plan on towing the trailer in your profile
21.42 ft.
Weight
Dry Weight
3,205 lbs.
Payload Capacity
645 lbs.
Hitch Weight
453 lbs.
and travel with your wife and 4 kids you are probably way over every limit imaginable . Even with a tow package I'm sure you're still way over
X2.
With that load you will fry the trans.
That would be my main concern also. All of these "grocery getter"/"Soccer Mom" vehicles just don't IMO have a robust enough drivetrain ... esp. the tranny to tow any full profile trailer. Reasonably sized pop-ups, cargo, and maybe boats, but not full profile TTs with their SIGNIFICANT WIND DRAG in addition to the weight and sail area.
I just believe if you want to really tow something "SAFELY" get a vehicle meant to actually tow and understand the tradeoff might be less ride comfort and daily non towing mpg.
Larry - westendExplorerBasically, Asian built vehicles are a pain when it comes to trailer wiring unless there is a factory installed plug to accomodate the 7 pin connection. This can be true even for an aftermarket 4 pin connection. Japanese like to break down their tail wiring into multiple electrical circuits whereas domestic trucks have fewer circuits and circuit protection is easier to work with. I'd suggest to research through online Oddesy owner's groups. Those guys are sharp and have done the work, previously.
IMO, a front wheel drive van is not a good match for hauling an RV but owners try to use what they have. Good luck with the Oddessy. It is probably one of the better vans built. I, too, recommend Tekonsha P2 or P3 as an aftermarket brake controller. If you search the Tekonsha website, you'll probably find the correct adaptor to wire the cabin side circuits that connect to the controler. I'd asume that an individual wire may be necessary for trailer brake control but have no direct experience with that vehicle. - Steve_911ExplorerI use a Prodigy RF wireless brake controller. Using it for about a year now, and no issues. I tow a 2017 Rpod 179...Works great with my 2016 Highlander w/tow pkg.
Hope that helps - afidelExplorer II
ScottG wrote:
21.42 ft.
Weight
Dry Weight
3,205 lbs.
Payload Capacity
645 lbs.
Hitch Weight
453 lbs.
X2.
Forget that, you'll not want to tow with the van the first time you go over a bump. With just the wife and I and a somewhat lighter trailer it didn't take but driving the van home over mostly flat ground to know we needed a truck. If you have a truck there is a 0% chance you'll want to tow anywhere with the van after you feel what the soft rear suspension feels like towing. - LwiddisNavigatorThere goes Boles saying what I should have said. OP will be seriously overloaded. There is a reason Honda doesn’t include a 7 pin plug...NOT meant for heavy towing. Another example of buying TV first and then...overloading.
- ScottGNomad
21.42 ft.
Weight
Dry Weight
3,205 lbs.
Payload Capacity
645 lbs.
Hitch Weight
453 lbs.
X2.
With that load you will fry the trans. - SoundGuyExplorer
brmiller wrote:
The Odyssey is my wife's car. I drive an F150 FX4 so it has no issues towing the trailer.
Was just hoping that with a trans and ps cooler and tow package we could tow an empty trailer.
guess that's not possible?
GVWR for this trailer is 3850 lbs, 350 lbs over the Ody's likely trailer tow rating of 3500 lbs ... I say "likely" because we have no idea of the year or trim level of your Ody. Possible? ... sure, but do you really want to start off by towing 10% over the vehicle's rating and have to be really careful about what you load into a trailer with such limited cargo capacity? Presumably you have a reason for wanting to tow with the Ody rather than your F150 but it doesn't sound like a good solution to me. Remember, it's not just about weight but also the significant effect of wind resistance that quadruples as road speed doubles. You'll feel that trailer behind the Ody for sure. Good luck. :) - MFLNomad II
SoundGuy wrote:
Bols2DawaLL wrote:
... if you don't have a factory tow package and you plan on towing the trailer in your profile ...
... and travel with your wife and 4 kids you are probably way over every limit imaginable . Even with a tow package I'm sure you're still way over
Best we can do is wish him lots of luck towing a Coleman Lantern 17FQ travel trailer with his Odyssey. Scary. :E
Not that it matters, but actually a family of 4. The OPs Honda is likely rated to tow 3,500, so may be over his drive train recommendation a ways fully loaded. No reason to turn this thread into a weight issue. At some time many of us have been over factory spec tow rating a little. I know I have BTDT. He has gotten some good info, concerning his question on brake controller.
Jerry - Ron3rdExplorer III
ScottG wrote:
I would just avoid time-delay based controllers.
A Prodigy P2 or P3 will serve your needs nicely and have a solid state pendulum (no moving parts).
X2. - brmillerExplorerThe Odyssey is my wife's car. I drive an F150 FX4 so it has no issues towing the trailer.
44,071 PostsLatest Activity: Sep 17, 2026
Related Content
- Feb 01, 2026Community Alumni
