cummins2014
Jan 10, 2017Explorer
kw/00 wrote:
I have aftermarket rims on my truck. They need to be rated the same or higher then the factory rims. Mine were rate higher then the original. I do believe there is a website out there that can sell you the original. I have seen in but can't recall the name, hopefully someone will chime in. Otherwise search out the aftermarket rims and make sure their rated load capacity is equal or higher then what you have now. A good tire shop can help you with this.
Depends on how picky you are ,but I had a heck of time finding a aftermarket wheel that matched the weight rating, and something I liked . It seemed the better I liked them the worse the weight rating was :) Finally found what I liked with the correct offset, correct weight rating, but was lug centric.
I agree on the tire shop ,although I did find the wheel I wanted by searching websites, but I bought from a local tire shop, they ordered the wheels.
